Date:    6-12-2016
Number of Hours:    1.00
Brief Description:    Beginning to make pine prop, to be transfered to h
Laminating pine wood boards together, for "rough draft" propeller. Will use duplicator to transfer to hard wood for actual one. Exploratory, if this doesn't workout i'll just buy a 54x30 propeller to use. Of important note the VW engine turns opposite normal aircraft engine which needs to be accounted for in construction of prop.
In addition I rough cut fuselage front bottom, and cockpit floor from 1/4'' plywood. placed order for 1/8'' plywood.
