2-3-2012 |
14.00 |
Wing assembly |
rib 8 - loctite belcrank nut. had to go out to factory again - bend was not right in doubler plate 3.5 deg. Trial fit skins. rivet ribs . remove plastic, Fit strobe wire . prime skins and flat when dry. fit lower skin - cleco. I have condensed this from the build log - need to get kitlog up to date. |
