Date:    5-5-2018
Number of Hours:    3.00
Brief Description:    Wing Wiring and brackets
Drilled holes in the conduit in the wing for both left and right landing lights. Also the stall warning wires and the wires for the fuel level senders.
I fabricated a bracket in install in the left wing. It will go outboard of the aileron bellcrank and have two grommets. One will hold the pitot line. If I install an AOA line in the pitot tube, it will hold that as well. Challenge now is to get the holes to line up.
