Date:    4-10-2017
Number of Hours:    2.00
Brief Description:    Leading Edge
Riveted the left leading edge ribs onto the spar. It took less than an hour since I knew what I was doing. The two outer ribs and the second outermost rib where I could reach with the bucking bar used AN470 rivets. The other three ribs used LP4-4 or LP4-3 as appropriate.
Squeezed about a third of the rivets through the spar flange.
