Date:    4-18-2014
Number of Hours:    5.00
Brief Description:    LL
Installed the landing light in the right leading edge. Went pretty well until I shattered the lense using an air drill. Used the spare and this time drilled everything using a rechargeable drill that can be set to drill at very slow speeds. Works much much better.
Had to pop rivet the retaining strips to the lens as the two sided tape supplied didn't work.
If found that you really don't need to trim the supplied lenses very much, cut about 3/4 of an inch off the top and bottom and didn't trim the width at all.
