12-2-2013 |
2.00 |
Spars & Conduit |
Drilled spar for the skin dimples. Pulled the conduit throught the rib holes. I was at a loss on how to do it and after reading a bunch of posts on VAF, decided just to "muscle it though" as recommended. Started at the outboard of the wing. I found that keeping the tubing under tension from both sides helped to elongate it and make it a little easier to pull through. |
