5-27-2013 |
3.00 |
Woodworking |
Bot some wood and built the leading edge cradle. Also raised the old dimpling table to work with the new dimpler. Had to use the router to cut new holes for the larger frame and the dimpling plate. Cleaned the garage. Heading out to the Mooney to look at the exhaust leak and chase down a loose connection in the PTT switch. Then maybe practice the commercial manouvers. |
