5-18-2013 |
4.00 |
Match drilled top skins |
After removing the wings, I found it was easier to cleco the skins in place with the wing flat on the bench and then lift the wing into place on the jig. I could then sit on the stool and drill the holes. Spent the afternoon/evening drilling. Took time off to drop Nathan at his date's for the prom. Thousands of pictures later I was drilling into the evening. Poor dogs were hiding across the yard from the drill. |
