7-19-2020 |
3.50 |
Mid-Fuselage Skins |
Prepared the seat rails and the seat floor assembly. Used a fly cutter to cut a hole for the vent tube in the seat rib. For some weird reason Vans instructs you to use a fly cutter in the drill press which is a little difficult given the rib is in an assembly. Used the drill press on the skin. Cleco'd the skins to the seat floor assembly. |
