Date:    5-9-2020
Number of Hours:    2.00
Brief Description:    Rudder Pedal brackets
Installed the rear seat rudder brackets. The instructions call for the bracket to be held in by one bolt while you use an angle drill to match drill the other hole. No way. Wasn't close to being able to do that. So I clamped the bracket in place, got a scrap screw, dipped it in model paint and slid it through the hole. Presto, instant mark where to drill.
Drilled and installed the two brackets which will hold the arms.
