5-10-2014 |
3.00 |
Cleanup and holes |
spent several hours removing cobwebs from the garage. Removed the sender/float from the left tank which has the flop tube then cut a hole around the sender hole. Will use the original plate for the wing root to close the hole and mount the fuel sender. |
