Date:    3-4-2012
Number of Hours:    2.00
Brief Description:    Drilled Elevator Horns
I haven't been able to find the right kind of steel tubing anywhere for drilling the elevator horns. I got some 0.25" OD PVC tubing and was able to use that but I am not sure the results line up perfectly. I will have to order the pipe from Aircraft Spruce which means I can't drill them until Friday probably.
