Date:    1-30-2011
Number of Hours:    4.00
Brief Description:    Front Spar Assembly and Ribs
Bent HS-810 and HS-814 to six degrees. Dimpled and counter-sank holes. Prepared HS-404 and HS-405 ribs. Drilled out the #40 holes in front spars. Cleco'ed rib/spar assembly.
