10-24-2010 |
7.00 |
Nose ribs W15-## |
Built the entire day making nose ribs (23 of 26, need to buy another sheet of .025) I usd the form block to cut the blamks on my router. Second I drilled the center holes for the 3 and 4 inch lightening holes. Finally drilled a 1/4 inch hole for the cut out at the rear (top and bottom) that mates to the main spair, then cut out the area with tin snips (picture 1 right side of blank) Then spent the rest of the evening cutting the 4" lightening hole. |
