10-7-2010 |
1.50 |
Aft wing rib assembly -04 |
W16-04 (two each). Picture 3 is from the next entry, when they are actually completed. As per the plans, -04 is offset (picture 1) to allow the spar caps to pertrude above and below the forward edge of the rib (as are 3-1 and 5, but incrementally larger. The ribs outboard of 5 are not. These 3 shots show holes drilled, then clecoed and finally complete. |
