9-6-2017 |
5.00 |
Tail surface attachment |
I attached the Ailerons and Flaps. As others have had, there was some interference with one of the push rods and a could rib lightening holes at full forward stick position (down elevator). I removed a small amout of material from each offending hole, and filed and sanded smooth from a very uncomfortable position. Good news is that I hadn't installed the bottom skin of the eppenage, otherwise it would have been nearly impossible. |
