5-6-2017 |
12.00 |
Updrilling wing mounting blocks to 3/8" |
I decided to updrill my spars outside of the plane using a borrowed 3/8" double margin non-cutting piloted drill bit. The drill bit made it practically impossible to mess this up. The pilot emerged on the other side of the spars perfectly centered in the 1/4" hole that it followed. This way, when the wings are installed, I can drill the vertical wing attagh anges by using a 3/8"OD -1/4"ID drill bushing, and a longer 1/4" drill bit, then updrill them to 3/8" with either the double margin bit, or a longer 3/8 drill bit. |
