4-29-2013 |
7.00 |
Left Main Spar |
Over the past couple days I've pilot drilled all the holes in the left main spar caps. Tonight I mounted the root attach block and a couple angles. I think I'm making pretty good progress, but I'm having some trouble with metal chips jamming between the web layers. This means I keep having to disassemble the spar, remove the chips, then reassemble before I can move on to the next part. |
