6-25-2015 |
15.00 |
Trim Lever and Glaresheild Fit |
With the fuselage upside down, I fabricated the seat, then installed it. Seeing that it fit fine, but would be in the way, I removed it for now I then installed the trim lever, and then flipped the fuselage over so it's right side up again. Cut the glareshild to size from Sonex supplied pre-bent form, and drilled the holes that will match up to the instrument panel. |
