5-31-2020 |
2.50 |
Installed the wings |
This was a pretty big day. Invited a few of the neighbors over (they showed up with a few hanger on-ers) to help install the wings. All went pretty well and we rolled the finished product back into the shop. BTW - I did discover that one of the aero fairings on a rear strut was not cut off enough to enable a full wing fold. It was close but not perfect. The best I can tell, when I laid out the cut the fairing wasn't all the way on the strut. It had been off and on several times for several fittings and cuttings (for the internal "V" joint at the inboard end) and apparently I hadn't put it back in the correct location prior to the final trailing edge layout. Not a big deal but - you've been notified. |
