Date:    12-24-2019
Number of Hours:    3.80
Brief Description:    Installed brake fluid reservoir
Spent time fine tuning the design of the aluminum plate that will stabilize the brake line coming out of the rear gear leg fairing and going to the brake caliper by wrapping around the axle.
Installed the brake fluid reservoir and determined how the lines from it to the pilot's pedals should be routed.
