11-14-2019 |
6.50 |
Installed 5th camloc and top cowl windshield flang |
Since I had to remove the top cowl to locate and installed the windshield flange base, I decided to remove the bottom cowl and see if the outboard rudder pedal bases could be removed easily. I was hoping that that would give access to the lower, forward camloc base and maybe the chance to back drill for the camloc itself. The short version of the story is it worked out but instead of back drilling I used a flashlight and illuminated the desired location on the cowl by shining a flashlight through a tube about one inch long fitted in the camloc receptacle. Next the top cowl windshield flange base was cut to size, fitted, and epoxied in place. . |
