7-2-2018 |
3.50 |
Finished co-pilot's window and prepped for H/T |
Finished the co-pilot's window and prepped for installing the ribs in the H/T and elevator. 1. For the window: same as pilot's window (see previous entry) 2. Laid out rib placement on the work bench. 3. Mounted the elevator to the H/T. 4. Blocked the assembly to the work table. 5. Fitted the two middle ribs and align drilled the bearing access holes. |
