6-1-2018 |
6.10 |
Final install of rudder pedals |
The replacement bolts came in and I spent the day installing the rudder pedals. Took longer than anticipated (doesn't it always?) because I took the time to: 1. Remove more friction from the assembly 2. Determine the proper hardware stack-up; required because I had added fender washers under the floorboards to "level" the rudder assembly 3. Add non-slip tape to the rudder pedals 4. Replace the kit supplied screws that mounted the assembly to the floor with bolts 5. Replace the internal bolts with drilled bolts because I feel they will or could be subject to rotation. |
