5-15-2018 |
5.70 |
Rudder pedal assembly |
Finished the rudder pedal assembly - match drilled the pilot's side (inside pedal), fitted the pedal bushings and cut the bushings to length, drilled the brake tubing routing holes in the mounting brackets, set the master cylinder mounting length (had to shorten two of the actuating rods due to the factory not drilling/tapping the clevis deep enough to meet the Kitfox requirements), and cleaned paint and welding bump from inside the torque tubes to match to the mounting bushing. |
