Date:    5-13-2018
Number of Hours:    5.20
Brief Description:    Prepared pedal assembly components
Performed the required modifications to the standard pedal pulley mounting control horns IAW the adjustable option.
Fabricated the cable restraining straps.
The above work took a little longer than normal due to solving an interference issue between one of the rudder cable pulleys and its mounting horn (misaligned mounting holes).
