Date:    5-12-2018
Number of Hours:    8.00
Brief Description:    Completed fitting flap handle
I'm fairly certain that the fit problems stemming from the misaligned flap handle mounting bushing have been solved. Ended up twisting the top of the console by shimming it counterclockwise (used a -10L washer under the front left corner where it mounted to the fuselage frame), opening the slot a bit on the right side, and rotating the flap detent a bit clockwise.
Then, trimmed to shape and fitted the side panels and started on the adjustable pedal assembly.
