Date:    6-4-2020
Number of Hours:    3.00
Brief Description:    Painted the inside of the lower cowl
Brushed on a coat of ceramic paint on the inside of the lower cowl. This is really a test to see if it will help when and if it comes time to clean the inside of the cowl later in the plane's life.
Installed reflective heat protection in the forward area of the lower cowl to protect it from the nearby exhaust pipes.
Began fitting the landing light lense on the right wing tip.
Banded the wing tip wires into a common cable and pulled into the rear spar.
