1-30-2019 |
2.50 |
Finished the Stewart System Test Panel |
Glued on the second piece of material on the test panel frame after shrinking the matching edge of the first piece of installed cloth to just under 250 degree.. Cut it to have an unsupported lap joint in an unsupported bay. Just wanted to see how to do it - don't believe I'll have such a feature in the plane. We'll see. Tautened the entire panel/frame to 300 degrees. Glued through the fabric to the center support - just to see if that would work in a pinch. It did. Glued on an inspection ring. |
