1-23-2019 |
1.10 |
Continued cutting instrument panel |
Continued fitting components in the instrument panel. Today was a bit tedious as it involved locating and drilling the mounting holes for the round instruments. A personal challenge is to not have to over enlarge the screw holes to get all of them in. Also, spent a lot of time (probably needlessly) shortening tabs onf the fuse block after I discovered that they could be used, in addition to the standoffs I plan on using, to hold proper position behind the panel. As a side (calendar) note; spent time installing the compressed air drying labyrinth. |
