5-25-2020 |
7.00 |
Painted stripe on upper cowl and spinner |
Applied bondo to the intersection of the individual struts where they join at the fuselage. Painted the strip on the upper cowl and the spinner. (The drying time between the 6 fog coats and one wet coat was excessively long due to high humidity.) Found another opportunity to zip tie two more lines together on the engine and did so. |
