4-26-2020 |
2.50 |
Sprayed primer on 3 parts and installed heat shiel |
Decided to spray another coat of primer on the console (had to over-sand an area to smooth out some rivet heads) and two new inspection covers. Also, in an abundance of caution, decided to add another heat shield to protect the oil return line on the pilot side of the engine. Spent about an hour going thru the manual to double check completions and to plan what few finishing tasks there are. |
