4-7-2020 |
6.50 |
Sprayed last coat in the port wing panel |
Riveted air flow control flanges on the lower cowling. (I'm concerned that there won't be sufficient pressure differential across the oil cooler - the main cowl intake and the oil cooler intake are close to each other - and am attempting to give it every chance possible.) Sprayed what I hope to be the last coat of primer on the left wing panel. Prepped the inside of the lower cowling for its upcoming ceramic coating. (Trying to add something that will make cleaning the cowl most easy.) |
