12-16-2019 |
5.00 |
Fabricate exhaust pipe close outs |
Remade one of the baffle mounting tabs - all of the cut and fit activity revealed a better design and that is what I went for. Fabricated two small plates that close off the exhaust pipe pass thru holes. As admitted earlier, I getting the holes exactly where you would like them is neigh onto impossible so they end up being larger than desired - plus - the manual calls for holes larger than needed. So, I am closing them off and to a small size. Took the muffler and number 4 exhaust pipe to a welder to have the new spring mounting tabs put on. Cut, via a series of trial and error, the baffle to fit the lower cowl. |
