Date:    12-12-2019
Number of Hours:    2.80
Brief Description:    Located and cut the exhaust pipe pass thru hole
Located where the exhaust pass through hole in the lower cowl should be and, via a series is iterative cuts, cut the hole.
Also, started designing where the oil cooler will be mounted.
