Date:    7-18-2019
Number of Hours:    9.00
Brief Description:    Update on paint booth and painting EkoFill - eleva
I've not been working on the Kitfox at full steam due to a kidney infection but I'm pretty much over that now. Fact is, this is a catch up entry as I have been doing a bit every day, just not enough to warrant turning on the ol computer and making these entries - so this is a makeup entry.
I think the paint booth is pretty much complete. I've had to run down an airflow issue and resolve that with added structure and more fans. I'm not convinced that I have enough lighting and will undoubtedly be adding more . . . . who would have guessed that six shop lights wouldn't be enough?
All of the empennage pieces are complete through the UV protective coating - sort of. I was doing some minor sanding and ironing of pinked edges when I noticed that my alter ego failed to install the re-enforcing tapes on the inboard ribs of the HS. I'm off to Oshkosh tomorrow - maybe the solution to sleeping on the job will be found there.
