Date:    11-13-2018
Number of Hours:    4.80
Brief Description:    Finished NSP light install and rivet flaperon
Aligned and rough installed the wing tip (NSP) lights after finish sanding to shape the necessary body putty.
Installed the beginnings of the pitot mounting base. I'm modifying the design to eliminate the two flanges in the factory set up and still allow ease of access should there ever be a need to repair, inspect or replace the pitot tube.
Installed the rivets on the trailing edge of one of the flaperons. Used solid rivets vs. the supplied pull rivets the tail of the pulled rivet is long and ugly.
Also, completed the last of the profiling sanding on the left wing number two rib.
