Date:    10-11-2018
Number of Hours:    7.00
Brief Description:    Fuel tank final fitting and fuel backing plates
Completed the aluminum plates that mount behind the fuel sight gages.
Completed final fit and install details for both wing tanks. I removed quite a bit of flange (mostly on the right tank) so as to be able to remove and re-install the fuel pick up probes (should that ever be necessary in the future) without too much special effort.
