Date:    9-21-2012
Number of Hours:    0.50
Brief Description:    #8 Countersunk Screw Hole Finder
I wanted to go ahead and install the nutplates for the wing root fairings while building the wings. In case the fairings are not pre-drilled, I wanted to be sure I could locate the holes accurately. I built a hole finder out of 0.016 aluminum with the bottom hole drilled to #19 and dimpled to #8 screw size. The top hole is drilled #40 and concentric with the dimpled bottom hole. I added a "handle" made from some left over stiffener stock.
