Date:    5-8-2012
Number of Hours:    2.25
Brief Description:    Drilled Aileron Bracket Reinforcement Plates
Located, drilled, and deburred both aileron bracket reinforcement plates, including the pushrod clearance hole. I used a unibit do remove most of the material from the pushrod hole, followed by my die grinder, files, 100 grit sandpaper, and maroon scotchbrite.
