3-13-2012 |
0.60 |
Part 3 - Trim Servo Mount |
I dimpled the trim servo mount parts -3 for the rivet holes, #6 for the screw holes, riveted the flanges to the cover, and installed the servo on the mount. Just to verify my previous fitting, I was able to get the assembly in the elevator, but I didn't screw it down because I want to drill a hole in the spar separate from the one used to acommodate the servo shaft, most likely centered on the hole already in the elevator horn weldment. Rivets This Task: 6 Rivets Total: 2157 |
