Date:    3-13-2012
Number of Hours:    1.50
Brief Description:    Part 1 - Left Elevator and Trim Tab Hinge
I used a piece of angle taped to the trailiing edge of the elevator to locate the trim tab fore/aft. (Photo 1) I used a couple of #40 drill bits to set the minimum gap at the outboard end of the tab. Before fitting the tab, I marked a rivet centerline 3/16" from the forward edge of the hinge. When I fit the tab, this centerline came out right in the middle of the holes (Photo 2). The gap came out 3/32" at the bottom and 1/4" at the top. (Photo 3) I may build another tab, but not right now.
After drilling the forward half of the hinge, I removed it, then deburred, prepped, and primed it. It'll be ready for riveting after the primer cures.
