1-20-2012 |
1.50 |
Dimpled Rudder Skins and Spar |
Not much time tonight, as I stayed over a bit at work to fax out my order to Van's for wing and fuselage kits. Also, went to see the movie "Red Tails" which opened tonight. I HIGHLY recommend it! Well, the title of this post just about says it all, other than cleaning the primer off of the traling edge of the inside of one of the rudder skins where I forgot to mask it off. This surface needs to be clean for whatever adhesive I use (probably proseal) to glue in the trailing edge wedge before riveting. I still need to prep and prime the stiffeners, ribs, and miscellaneous parts before starting to rivet the rudder. Riveting the horizontal stabilizer is the plan for tomorrow. |
