3-16-2018 |
1.30 |
1 - Flap Adjustment |
Installed both flaps and adjusted both pushrods so that both flaps are fully retracted at the same time. Reinstalled the flap actuator with all hardware called for on DWG 33, except for safety wiring the lower rod end as shown in Detail E. Cycled the flaps and measured the top surface angles at the second rib from the inboard end: Right, Retracted 10.1; Extended 55.6; Travel 45.5 Left, Retracted 9.9; Extended 55.5;Travel 45.6 I want to have another set of eyes look at the pushrod clearances before removing the wings. (Done 3/17/2018 by Greg Heckler (RV-7A) and Jack Haviland (RV-6A) |
