Date:    3-15-2018
Number of Hours:    2.60
Brief Description:    Flap Pushrods
Completed hole for right flap pushrod hole by allowing for stop to stop rotation of the lower rod end bearing in the fully retracted position. Started and completed left flap pushrod hole. The holes are quite rough, so I will have to clean up the shape by hand a little and do some deburring.
The next step is to reinstall the actuator and check pushrod fits at both ends of travel, then check actual travel.
