1-25-2014 |
1.20 |
Center Fuselage - Electric Ailron Trim |
My new F-7123 aileron trim pivot block came in from Vans yesterday, so I got it drilled (correctly this time), and match drilled it to the bracket. While I was at it, accomplished the bend in the pivot arm, and drilled the steel tube on the pivot arm for its cotter pin. This should be enough fabrication to allow the servo and pivot arm to be final assembled to the seat ribs. |
