Date:    3-9-2007
Number of Hours:    5.00
Brief Description:    Battery Mount, fuse panel
Decided against mounting the battery in the nose and mounted under the passenger seat. Works great be removing two bolts and tilting seat up for access. Wire runs will be shorter as well.
Made up a bracket to mount the fuse panel at the front right in the nose cone.
Reconfigured the fuel routing to make it simpler. Mounted mikuni fuel pump with ine of the stainless hing brackets.
