1-31-2007 |
1.00 |
Nose cone |
Aligned nose cone with laser attached to root tube. I double checked with a plumb line extended from the root tube with steel tubing.Both methods concurred so I know the nose is straight.Drilled three holes along the top as well as the bottom. Will install rivnuts to allow for future removal. |
