Date:    2-1-2020
Number of Hours:    1.00
Brief Description:    Install Transition Piece in Aft Heat Duct
Removed the peel ply and trimmed the excess fiberglass from the aft heat duct.
Drilled the seatbelt anchor holes out.
Sanded the aft heat duct then cut a hole in the top of the heat duct for the transition piece.
Workshop temperature 20 deg C and 41% humidity.
Mixed 12g resin and 4g hardner with some flox to make a thick batch of flox.
Flox'd the transition piece in place.
