Date:    7-2-2020
Number of Hours:    0.50
Brief Description:    Repair hole in the nose
This project had a hole on the left side of the nose and no ballast compartment. I filled the hole with foam pieces held in place with 5 min epoxy. Next up I will finish shaping the foam, filling in any additional low areas and mark the location where the ballast hatch should be installed.
